For those of us running Aux Fed subs, it would be great to have a finer level of control over the cross over region. On the Ui-24 for instance, you can select 12, 24 or 36 db/octave slopes for the hpf/lpf. This would be a huge help for Aux Fed subs.
Note that I am breaking my previous suggestion into 2 separate topocs as suggested in that thread.
Agreed! This would be a handy feature. If soundcraft can include that feature being released in 2017 logically it should be simple enough to include or add via update on more modern digital mixers. The usefulness of such a feature still is applies even in smaller venues and where less channel counts are used and not a complicated functionality. Those have no need to change these slopes on anything or don’t even know about such slopes can leave on the default slopes requiring no actions but it would be there as a tool.
Just adding dedicated lpf on channels and outputs on cq would be great start so you don’t have o lose 4th band of eq to set as lpf (some times thats fine but other times that 4th band is needed for something else). To me 4 band paremtric eq plus hpf and lpf on every channel and same on outputs but with 6 parametric bands should be the minimum standard on digital mixers.
I would like to see this, I was surprised it wasn’t in there already when I first needed it, as running subs seems a very basic function for even a small band. It is currently rather an annoying omission. Obviously it will be limited in scope compared to custom-matched filters for particular cabinets, but useful nonetheless.
